AutoCAD Forum
dotted line
8 REPLIES 8
Message 1 of 9
pmc288
476 Views, 8 Replies
dotted line
Hi all, ive been managing around the software until i tried to dot a line to make it look as though it was travelling behind an object.  This is all well and good on the model until i look at layout.  Why does this reestablish a solid line on printout, and how do i keep the dots/dash?
Tags (4)
8 REPLIES 8
Message 2 of 9
MatiasWendt
in reply to: pmc288
Hello..
You need to change the Linetype Scale in the properties window by selecting the dotted lines.
Se a resposta resolveu o seu problema clique em ACEITAR SOLUÇÃO, isso ajuda os outros usuários a encontrar rapidamente uma resposta, e se gostou, cliquem em CURTIR.
Matias I. Wendt
YouTube | Facebook | LinkedIn | Instagram
Message 3 of 9
pmc288
in reply to: MatiasWendt
Hi, its says 1 then a calculator appears, do i just put 0.5 or similar?
when i change it to 0.5 the lines are smaller and they disappear in layout?
Message 4 of 9
ian.mag
in reply to: pmc288
Hey,
Agile in the paperspace, make the viewport active and set PSLTSCALE  to 0. Do a REGEN and let us know the result.
Message 5 of 9
MatiasWendt
in reply to: pmc288
In the area highlighted below you can enter any scale value.
the important thing is to keep to keep the same scale fatod used in your Viewport
Matias I. Wendt
Message 6 of 9
pmc288
in reply to: pmc288
sorry folks but non of the replies make sense ill go on youtube
Message 7 of 9
ian.mag
in reply to: pmc288
Hey,
What's the value for the system variable PSLTSCALE while in the paperspace (make sure your viewport is active begre you invoke the command)?
Message 8 of 9
imadHabash
in reply to: pmc288
try to pick inside your viewport and change PSLTSCALE value .
Imad Habash
Message 9 of 9
pendean
in reply to: pmc288
What are your settings for LTSCALE, PSLTSCALE and MSLTSCALE in modelspace in that DWG file?
And what is the PSLTSCALE set to inside that viewport in that layout?
Forma Design Contest
