AutoCAD Forum
Dotted Border around Paper Space
6 REPLIES 6
42039 Views, 6 Replies
What does the dotted border in paper space represent?
How do I move the distance of this line from the edge of the page?
I've attached two images of the line in two different locations.
Thanks in advance!
6 REPLIES 6
john.vellek
Hi @Anonymous,
The dotted line is a representation of the margins you have defined in your printer configuration. If you want to set them to 0 value, open the PC3 file and select Modify Standard Paper Sizes. You can set all the margins to 0.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
JDMather
In other words, the printable boundary edge for your printer - it can not print right out the edge of the sheet of paper.
(well, at least most can't)
This gives you a visual indication to stay within the lines - or it won't get printed.
in reply to: JDMather
why would it be missing is there a way to turn it on and off?
cadffm
- Options
-- Display
--- [Layout elements...                              ]     (lower left part of dialog)
add:
Or it is ON but not visible bcause of border=0 and paper=ON, so printable borders and paper-borders are congruent
Sebastian
in reply to: cadffm
Thanks for the help!!
very useful! 🙂
AutoCAD Inside the Factory
