DOCK INLINE WITH STATUS BAR funky behavior
Message 1 of 51
In AutoCAD 2016 when I choose "Dock Inline with Status Bar" by right clicking on a model or layout tab it doesn't stay docked.
Here's what happens. I have my AutoCAD window maximized.  I choose "Dock Inline with Status Bar" from a model or layout tab.  As soon as I use the Pan or Move command the model and layout tabs undock and raise above the status bar, even though the AutoCAD window is maximized.  I am only using one model and one layout tab.
Here's the funky thing: if my AutoCAd window is not maximized it stays docked with the status bar.
How do I make it persistent?
Replies (50)
Message 2 of 51
nrz13
I can't reproduce this issue.
Have you tried restarting AutoCAD to see if the problem goes away then?  If that doesn't work, you could try to Reset AutoCAD to Defaults, but note that will wipe out all of your customizations and AutoCAD will have to be reconfigured from scratch.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 3 of 51
Restarting didn't help. Not worth the trouble to Reset.
Thank you.
Message 4 of 51
I wonder if there's a system variable that would force it to stay docked.
Message 5 of 51
nrz13
Whatever variable controlling it appears to not be sticking, which is why I suggested the Reset.  I know it's overkill and, like you said, not worth the trouble of it, but that's the only thing I can think of that would reset that value in the Windows Registry.
Message 6 of 51
Pnmiller46
I have the same probably and I have reset everything and it still happens. It only happons on my laptop, not my desktop. Could that be part of the issue?
Message 7 of 51
nrz13
I don't have any other ideas as to why this would be happening.  I would report it to Autodesk through your Autodesk Account (if you're on subscription).  If you don't have subscription support, then report it here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Message 8 of 51
Message 9 of 51
csalvian
I have the exact same issue on my desktop computer. When the window is maximized (which it is by default) the status jumps up and down with the pan command. I have a 27" monitor so I want my AutoCAD window as big as I can get it. Has anyone found a solution which doesn't involve using autocad non-maximised? Chris
Message 10 of 51
When I right click on any of my tabs (model, work, layout, doesn't matter) the "Dock Inline with Status Bar" option is greyed out and not selectable.  How do I fix this?
Message 11 of 51
Alfred.NESWADBA
This happens when there is not enough place to move it down.
When you remove icons from the status bar or make the applicataion window of AutoCAD more wide then the option will get available.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 12 of 51
schurthing
Hi, I'm resurrecting this thread because I have been having this same maddening issue for a long time.
If I select "Dock inline with status bar" from the right-click options menu, it will do that temporarily, but once I start working again it bounces between that and "Dock above status bar", and in the process it moves the main drafting window up and down and I feel like I'm playing whack-a-mole trying to pick objects and edit.
All the super-obvious suggestions mentioned above do not solve the issue.
Does anyone know how to force that thing to stay?  Screenshot attached.
Stefanie
crazy autocad witch since release 8 😄
Message 13 of 51
csalvian
The only way I found to get it to work properly was with having AutoCAD non-maximised but filling the entire screen. As soon as I hit the maximise button, it would start doing it again.
Chris
Message 14 of 51
john.vellek
Hi @schurthing,
I just found this variable STATUSBARAUTOWRAP
Try setting the value to OFF and let me know if that helps correct the issue.
John Vellek
Message 15 of 51
scot-65
Boy, did you ever find that elusive needle in the haystack!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 16 of 51
john.vellek
HI @scot-65,
I hope it helps!
John Vellek
Message 17 of 51
schurthing
Hey wow @john.vellek, that worked! Wish I can "Accept as Solution", but it's not my thread.
That is a super-secret sysvar! A search in the AutoCAD help and Google turned up nothing. Thanks for sharing it!
Stefanie
Message 18 of 51
csalvian
**** that seems to have fixed it! Smiley Very Happy
Well done sir....well done.
Message 19 of 51
I have the same issue is 2018, I unchecked everything on my status bar and it is still toggling up and down. I typed in STATUSBAR and set it to "0" and that seems to work but I still use some of the options on the status bar.
Message 20 of 51
same issue in 2018, I unchecked every option in my status bar and it still does it. tried STATUSBAR "0" which seems to work but I use to use some of the option on my status bar.
