Divide line
Divide line
sarinaliyath_joy
Divide line
sarinaliyath_joy
I am looking for a way to divide a line into various lengths. I have attached an image for reference. The line needs to be divided into a particular length with both edges maintained at a certain distance. In between, I need points with a maximum distance of 300mm or less. The points should be equally spaced. Is it possible to do this, or is there an easier method available?Screenshot 2024-01-18 144104.jpg
apjones
The divide command will place nodes (points) along the length of a selected line based on the number of divisions you provide.  i.e. "Divide" (Select line) Enter number of segments: "4".
This would place 3 nodes (points) along the line. You can use these as a reference to break the line or otherwise make edits.
The nodes do not update with the line as it changes.  They are static.
There is also a block option to the divide command.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Kent1Cooper
This is one of the things that the DIV+ command in DivideMeasurePlus.lsp is exactly for -- available >here<.  Three of its enhancements over regular DIVIDE [among many others] that are relevant to your request:
It can take a User-specified Maximum spacing, and divide the length into the smallest number of spaces required such that they do not exceed that maximum.
It can inset the end-most division points by a User-specified distance [and the maximum-spacing division will be calculated for the remaining distance between those inset locations].
It can mark the division points with perpendicular Lines of User-specified length [as well as the usual Points or Blocks, and also with any User-selected existing object(s)].
Read the comments at the top of the file.
Kent Cooper, AIA
