Add attribute 'link' to spline and export to Navisworks or ifc
nathan_torggler
nathan_torggler
Hi there,
I would like to create a closed spline or a point (dot) in Autocad and add an attribute to spline with a link. For example Google Streetview.
The purpose is to import file then to Navisworks and to allow with a click to open the link. Is this possible?
As alternative an export of the spline to ifc including the link would also be helpful.
Greetings
pendean
Community Legend
Community Legend
@nathan_torggler wrote:
...The purpose is to import file then to Navisworks and to allow with a click to open the link. Is this possible?
Did you test it? I suspect the results match this post from Autodesk on the topic this https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Imported-URL-param...
You should be posting in the NW forum for options if any, here is the link https://forums.autodesk.com/t5/navisworks/ct-p/4
