Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I was working in paper space and everything was fine but suddenly all text disappeared and only shown when i select it. Also some bloks are not shown correctly. There was the same problem when i tried to open some other project that was ok before. There are not any layers that are frozer or turned off. I tried with regan but it didnt solve problem. Version is 2016..
@ivanaradulovic Yes I have had this problem before. I am adding a short video of how to get the text to show up again in paper space. Please let me know how this works for you and stay safe.
Two ideas ...
the text is set to be annotative, but not matching with the current scale, try to set ANNOALLVISIBLE to 1
you have assigned the text a layer (or a color) and the layer-/color is converted by CTB or STB to a color which is the same (or close to) the background color you use for the paperspace. Try to change the plot-style in the plot-dialog to "None"
If nothing helps then please show us the dwg-file.
- alfred -
have you tried my suggestions about ANNOALLVISIBLE, turning off usage of CTB/STB?
If yes, and that does not help, then please upload the dwg-file.
- alfred -
PS: please us screenshots, not photos from your screen as (at least I) can't see the details...
It's hard to tell from your photos (as others have suggested, a "Print Screen" screenshot would be better), but is there a hatch under your floor plan? I've had issues before where text and/or other objects display behind a hatch, but are actually on top of the hatch because you can click the object without having cycle through the selection.
If that is the scenario you have, send your hatch to the back: DRAWORDER > Back.
