Hello & Help !
Case :
I have a vertical line. I want to displace the bottom anchor of it 3Cm left/right without changing the position of the top anchor. I want to do this by inputting a numerical horizontal left/right displacement value in the dynamic input boxes. I do not want to displace with an input for an angle value because i often do not know what the resulting angle will be.
So i click the bottom anchor, move the cursor left/right and enter a numeric value, say 3 Cm. I do this with "Ortho" mode ON to preserve displacement of the anchor along (0º / Horizontal displacement of anchor only). Note in the screen shot marked with red, this is exactly what i want to do, displace horizontally right 0.03Cm right with the anchor moving along a 0º angle.
What i end up getting is the whole line being lengthened or shortened in other cases along the same angle axis it originally was rather than bottom anchor being displaced horizontally as i was attempting to do. So if it was a vertical line it extends or shortens vertically, if it was at a 45º angle for instance it extend or shortens along the 45º angle as well.
I face this nuisance countless times daily and my work around is to either fine tune it manually which is often inaccurate and takes much time that i could be otherwise working on my design.
I know the answer is out there, so help me guys please.
Thanks to everyone who chips in with their knowledge here,
Cheer !
