DISAPPEARING TEXT
DISAPPEARING TEXT
DISAPPEARING TEXT
AFTER TYPING TEXT I AM MOVING THE CURSOR TO ANOTHER AREA, CLICKING AND PRESSING ESC. ON DOING THIS THE TEXT IS DISAPPEARING ! I HAVE USED THIS METHOD BEFORE AND IT WORKED FINE.
i HAVE ACCIDENTALLY CHANGED SOMETHING TO MAKE THIS HAPPEN OR AM I USING AN INCORRECT METHOD ?
imadHabash
when click Esc , that's telling AutoCAD to NOT save your procedure !! would you tell us more what exactly the command that you use for texting ?
Imad Habash
HI
THX FOR YOUR REPLY.
OK SO MY PROCEDURE IS
SELECT SINGLE OR MULTILINE TEXT FROM THE TOP RIBBON - DRAW A VERTICAL LINE TO SET THE HEIGHT OF THE TEXT - CLICK - DRAG THE DASHED LINE INTO THE DESIRED DIRECTION OF THE THE - CLICK - TYPE TEXT - MOVE CURSOR TO ANOTHER PART OF THE SCREEN - CLICK - ESC.
THIS WAS HOW IS WAS INSTRUCTED TO DO IT AND HAS WORKED IN THE PAST.
THANKS FOR YOUR HELP
imadHabash
instead of ESC use Enter keyboard button .
Imad Habash
HI AGAIN
I HAVE TRIED YOUR SUGGESTION BUT UNFORTUNATELY I DOES'NT WORK WHETHER I USE ESC OR ENTER/RETURN COMMANDS AFTER TYPING THE TEXT, IT ALLWAYS DISAPPEARS
I WONDERED IF YOU HAVE ANY FURTHER SUGGESTIONS PLEASE
imadHabash
as you can see below it's work after asking about height and rotation . i'm afraid that your current layer is OFF make sure that your current layer is ON .
Imad Habash
HI IMAD
HEY SUCCESS !!!
THANK YOU SO MUCH FOR YOUR TIME 😁😁
