Disappearing 3D Solids
So, some 3d solids have disapperead from the drawing for no apparent reason.
How the event happened:
  1. I saved the corrrect file and closed autocad;
  2. I opened the file (note: the preview thumbnail showed the drawing with all the 3d solid still in place)
  3. Some 3d solid have disappeared from view. At start this object were flickering in view when zooming or orbiting but after a while they were gone for good.
  4. I'm unable to select the missing objects with the mouse in the drawing, but if I right-click and choose "select similar object" on one of those still in view, they all showed up in the property tab: the number of selected objects is greater than the object visually highlighted in the drawing space. (see picture below)
Note the Move Gizmo in the above picture: if I had selected only the 3d solid highlighted in model space, it would be located in the centroid of the solid; here it is exactly halfway between the centroid and the UCS origin of the drawing.
What I already tried unsuccessfully:
  1. audit/purging the whole drawing
  2. revert back to a back up
  3. copy and paste the selection (including the invisible objects) in a new drawing
  4. checking for freezed layer and hided objects
  5. changing view, visual style
  6. issuing the commands: regen, regen3, redraw all
  7. zooming to the extents of the drawing
I don't know what to do. This is really unsettling beacuse I don't know what have caused it and it means the autocad is unrealiable in the 3d modeling, I risk to lose hours of work at random. This problem happen at least twice on the same file, indeed the number of selected items in the property tab should be 2 instead of 3, but I recovered from that simply by making a new 3d solid because what an easy job of copy and paste. But as the drawing grow in complexity this is no longer a viable solution.
The attached file should be untouched save I made before the 3d solid went missing.
stevetamplen
Hello s.follador;
Please look over this Forum post:
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/disappearing-3d-solids/m-p/5912167/hi...
It seems to describe your issue exactly.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Steve Tamplen
Technical Support Specialist
the suggested topic is very relevant, but I don't feel to accept it as solution because that solution proposed in the thread do not work for me, and, as it seems, neither for them: they were not able to fix their file and had to redo most of the work.
By the way, I since moved on, so you can close the topic, but just be aware that the issue is not resolved.
