Disable/Prevent XREF Selection
LuisMCosta
Message 1 of 24
LuisMCosta
Hello everyobdy,
Is there a way to disable/prevent selection of XREF elements? I want to have it in my drawing but unable to be selected.
Thx in advance
Replies (23)
Message 2 of 24
imadHabash
HI,
since your xref appeared at your screen this means that it will be selectable item. BUT if you lock the xref layers,this will help some how on your work.
Imad Habash
Message 3 of 24
rkmcswain
Put the Xrefs on one or more unique layers, and lock those one or more layers.
Message 4 of 24
Kent1Cooper
Putting XREFs on locked Layers will prevent altering them [Erasing, Moving, etc.], but as @imadHabash mentioned, will not prevent them from being selected.  [You could, for example, still select them to view their Properties, whether in the Properties box or a LIST command, or use elements in them as EXTEND or TRIM or HATCH boundaries.]
If you want them to be entirely unselectable for any reason, there is one way I know of to do that, but it's a rather weird workaround, and you may have several good reasons not to do it.  But if not, it "works": put them on the DEFPOINTS Layer, and turn off or freeze Layer 0.  For some reason, when Layer 0 is off or frozen, things on the DEFPOINTS Layer are still visible, but can't be either selected or Osnapped to.
Kent Cooper, AIA
Message 5 of 24
Sorry for bumping this but this thing has been driving me mad, I keep selecting the xref and it throws me off my flow 😉
I'm _very_ new to the whole AutoCAD thing and I'm having some trouble figuring out how to move the xref to the DEFPOINTS layer.
Where and how do I do that?
Think it's kind of odd that this thing isn't default or easier to change, cause why would you like to be able to select the "background"? Or am I completely missing the point and use of the xref?
Oh, I forgot, hi all! 😉
Message 6 of 24
rkmcswain
sutnoppontus wrote:
.... how to move the xref to the DEFPOINTS layer.
It's actually no different than changing the layer of any other entity. Select the entity and then in the Properties palette, change the layer.
Message 7 of 24
Thanks for a quick answer!
But I'm afraid it didn't help, cause even if I do like that the thing I have in xref only reacts to if I make the xref layer visible or not, nothing happens when I do the same for defpoints and the xref is still possible to select in the drawing. 😞
Message 8 of 24
Patchy
Turn OFF layer zero too
Message 9 of 24
Kent1Cooper
@sutnoppontus wrote:
.... the xref is still possible to select in the drawing. 😞
... or Freeze Layer 0 -- either Off or Frozen works [see the end of Post 4].
Kent Cooper, AIA
Message 10 of 24
cadffm
Guys, please not propulate this scary way.
Crying loud, Sebastian.
Sebastian
Message 11 of 24
Yes I did so before my previous post but maybe I'm experiencing a different issue than what's talked about in this thread. Kind of difficult to keep track on all of these new expressions. Think I'll need to try getting help a little more "hands on" or something.
Message 12 of 24
Kent1Cooper
I agree that it's not  advisable to either user the DEFPOINTS Layer for things that are not Definition Points, or turn off or freeze Layer 0.  But I don't know of any other way for something to be visible but neither selectable nor Osnappable.  If that's what they really  need, this may be the only way.  But I would also encourage them to find another way to control what's happening, if possible.
Kent Cooper, AIA
Message 13 of 24
cadffm
Yes, there is no other ootb solution.
Only (other) way for fullversion-user is small a program extension to controle the selection.
20-30 lines for basic Lisp code. Should possible to find working code. Keyword for sourcecode: vlr-miscellaneous-reactor and ssgetfirst.
Sebastian
Message 14 of 24
Haider_of_Sweden
Oldie but goldie.
This trick works, thank you @Kent1Cooper , but I am trying to understand why. I also try to understand if I can put the Xref in another layer with the same result.
Any new info on this one?
Message 15 of 24
ВeekeeCZ
I love THIS  free app, made by R. Stima. One of the must-have apps on my list.
The app allows you to set for each XREF whether it would be selectable or/and snappable.
Message 16 of 24
Haider_of_Sweden
Thanks for the tip. I will try it out soon. But for the sake of my curiosity, I'd like to know if there is a built in method as well.
Or: if someone knows the reason why the previously mentioned workaround with Defpoints works.
Message 17 of 24
Haider_of_Sweden
Coulldn't edit my post, to I'll reply instead.
"Xref Tools Extra" by Richard Stima is really cool. However, you need to  have the tool installed for eg "Selectable" to work.
If you only need this feature while you're working on your project, then it should be fine. If however you want the effect to be present in the project the whole time, then the workaround (defpoint) is the option you have today.
Therefore, if anyone could provide another solution or explanation, it would benefit the community.
Message 18 of 24
RobDraw
There is no direct way to make anything unselectable.
Rob
Message 19 of 24
susanne.mirsoyanH9BD2
Observer
Observer
1. Go to Options
2. Choose Selection (at the end)
3. Under Preview, click Visual Effect Settings...
4. Under Selection Preview Filter check the Xrefs under Exclude.
Message 20 of 24
RobDraw
@susanne.mirsoyanH9BD2 wrote:
1. Go to Options
That's visual settings. It does nothing to prevent selection.
Rob
