Disable AEC object error message
I am looking for a way to disable the AEC object error.  I have drawings that were worked on in 2015, then saved down to 2010.  I am batch processing these drawings in 2010, and the graphics that are related to the AEC errors are not problematic graphics at all.  It is a massive annoyance, and I do not want to delete them.  I also cannot sit and hit enter every time the dialog appears while I am processing 6000 drawings overnight.
Can anyone help?  The only solutions I have seen online are to explode the objects which is not a solution at all.
Thank you.
Alfred.NESWADBA
you can run command -EXPORTTOAUTOCAD (or -AECEXPORTTOAUTOCAD) to remove the internal AEC-information from the drawing.
If you want to run that with multiple files you can start _DWGCONVERT and create a conversion setup which explodes the AEC objects.
BTW: when the dialog appears, doesn't that dialog have a checkbox for "do this every time" (...or so?) ?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
wispoxy
This explodes those objects so they will become AutoCAD Lines/Arc/Circles/etc.  In doing this they will lose their smart properties when brought back into AutoCAD..
pendean
Community Legend
Community Legend
That's the reality of AEC objects and saving down to a lower DWG format.
Either explode them, or stop using the higher (or lower) DWG format AutoCAD variant altogether: you decide. There is no other solution.
wispoxy
Download DWG Trueview: http://www.autodesk.com/products/dwg/viewers
Conversions are simple with the application, and it's free.
