Dimstyle will not accept a text height lower than .04?
jmmolinaSKUTX
Message 1 of 9
jmmolinaSKUTX
I need to change my text height to .02 for a certain part of my drawing but when I set that in Dimstyle it gives me a 0" in the text height section. It does not allow me to press ok to accept the .02 height how can I change this?
I know AutoCAD is capable of .02 cause I can manually change the text height to .02 in properties.
Replies (8)
Message 2 of 9
JCKRU47
Message 3 of 9
rkmcswain
So what is stopping you? Is AutoCAD giving you an error when you try to set it?
It works fine here. Can you share the DWG file (or at least a stripped down version that still exhibits the problem)?
Message 4 of 9
jmmolinaSKUTX
It is not letting me press ok it dings at me when I press ok and does nothing.
Message 5 of 9
pendean
Community Legend
Community Legend
@jmmolinaSKUTX why not start STYLE command and see if you've already hard-set your text height for that text style to be something other than 0 (zero), aka you are fighting your own settings.
Message 6 of 9
jmmolinaSKUTX
I don't think that's the issue I don't see anything that would limit that.
Message 7 of 9
jmmolinaSKUTX
Not sure why but when I went to a different dim style it allowed me to set THAT one below .04.
Message 8 of 9
cadffm
If you like an answer without guessing,
Share your DWG
We don't need lines or blocks, but the dimstyle.
Sebastian
Message 9 of 9
rkmcswain
@jmmolinaSKUTX - you have been asked twice to share the DWG file. We are all just guessing at this point. Please share the DWG file. Thanks.
