Hi there,
I am working on a drawing and for inexplicable reason all dimensions and MLeaders where exploded.
Is a command or lisp to fix this?
Solved by pendean. Go to Solution.
Your options are limited. May have to Restore previous version or Restore a Drawing From a Backup File.
Also, make sure the DIMASSOC is not set to 0 (zero).
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
@l_campanelliQRYHF wrote:
thanks for the idea, but I don't have access to it. I received the file from another company.
you'll need to ask them why: there is no ability to put back together exploded dimensions at all. Sorry.
There are LISP to recreate MLEADERs from MTEXT, but you'll have to have MTEXT and a defined MLEADERSTYLE in place too.
Looks like "they" did that deliberately to limit your ability to use their content.
