Dimensions
neil
Dimensions
neil
I am working on existing drawing previously created. I have moved the dimensions into model space. I now cannot grab a handle and change the dimension. it immediately unselects it. not on locked layer or constrained. I copied lines and dimensions from another drawing and pasted and can move them fine.
Replies (15)
dbroad
Sounds like pickfirst and grips are both set to 0.  If that is not the issue, attach a copy of your drawing with only a single non-functional dimension.
Architect, Registered NC, VA, SC, & GA.
neil
Pickfirst was set to 1
Grips was set to 2
All dimensions inside of cloud non-functional
Neil Frank
Tru-Steel Corporation
3208 Industrial 31st Street
Fort Pierce, FL 34946
Ph (772) 460-3101
Fax (772) 460-3103
Cell (772) 828-0269
Neil@Tru-Steel.com
neil
Grips was set to 2
Neil Frank
Ph (772) 460-3101
Fax (772) 460-3103
Cell (772) 828-0269
Neil@Tru-Steel.com
pendean
Community Legend
Community Legend
>>>...I have moved the dimensions into model space...<<<
Explain process. Post DWG file, let's all have a go too.
neil
To move dimensions into model space, I highlight the dimensions in paper
space then use the change space command.
Neil Frank
Ph (772) 460-3101
Fax (772) 460-3103
Cell (772) 828-0269
Neil@Tru-Steel.com
neil
Neil Frank
Ph (772) 460-3101
Fax (772) 460-3103
Cell (772) 828-0269
Neil@Tru-Steel.com
pendean
Community Legend
Community Legend
Post your DWG file (or a portion of it) with the locked-up dimensions please.
neil
I am new at this community thing. How do I do that? Thanks
neil
dbroad
I hope you are posting by using the forum interface.  If so, under the body, where you write your message are other controls and buttons.  Look for the attachments section and push the browse button.
pendean
Community Legend
Community Legend
Come to the website, hit the REPLY button, and post the DWG file. You cannot post a file by replying to the email your get.
neil
sorry for delay. I was out of town for holiday, attached is the dwg file
skintsubby
I'm not sure how you done your dims. But......Your UCS is not aligned to your model space dimensions.
Check how to align the UCS
neil
after looking at looking at model form all directions, I now can see that the object lines at on the Z0 plane but if I look from front or left/ right view I can see that the dimensions are on a plane below 0 and at slight angle. I am not sure how to fix but I do now have an idea on how it happened. Sometimes when I move a view sideways in a viewport I push the middle button on mouse to pan then I hold shift key down to make sure it moves directly sideways and doesn't move up or down in the viewport. however I have found that if you hold down shift key first then middle mouse key it actually starts to orbit. I must have tilted the model just slightly (not enough to notice) and then started to dimension. and when I changed the dimensions from paper to model space it threw them below Z0 axis
Thanks for your help
dbroad
To fix it, delete and re-dimension. Easiest part of CAD is dimensioning.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
