Show only
Search instead for
HELLO, I want to ask if there is any API that can help me extract dimensions from a draw to excel (let's say I draw a simple cube can I extract the Of X ,Y,Z axis to a table form in excel )
Sure, you can extract attribute information from blocks into a table object or CSV file for use in another application like Excel. The Data Extraction wizard is the most efficient way to extract attribute information. It can also be used to extract property values that are associated with the other types of geometry defined in a drawing along with general information about a drawing file.
Please"Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
