Dimensions Not Displaying Text
tobynussenzweig
tobynussenzweig
See attached, I'm not sure how to get CAD to display dimension text. It's showing a center mark but not displaying text...?
Thanks in advance!
vinodkl
Hello @tobynussenzweig
The text size and the arrow size of the dimension are very small so it's not visible. Type in the command "DIMSTYLE" and then select "modify". Now click on the "text" tab and modify the text size also do the same with the arrow size in the "symbols and arrow size" tab. Please find the drawing attached for your reference 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Kent1Cooper
The more standard way is to set the text height and arrow size to what you want them to be on paper when Plotted [e.g. text at 1/8", 3/32", whatever], and if not using Annotative Dimensions, set an overall scale for Dimension "features" that is the ratio of reality to the Plotted scale, for example if intended for 1/8"=1'-0" Plotting:
When using Annotative Dimensions, the text height and arrow size will then adjust themselves to the Annotation scale of each Viewport, so that you can Plot in multiple scales on the same sheet with the same Dimension Style.  That requires the on-paper-size setting for text height.
Kent Cooper, AIA
tobynussenzweig
Man, that's pretty embarrassing...
Thanks for your help!!
tobynussenzweig
Thank you, I appreciate the insight!!
