I recently installed AutoCAD 2016 64-bit, and I found a bug with dimensions disappearing. I had multiple drawings open. I switched to one drawing, did some work, then came back later to original dwg. When I did that, all DIMENSION objects were gone. Other objects on my DIM layer were still there, including text and LEADER objects. Only DIMENSION objects were gone. So I put the dimensions back in and kept on working. It did the same thing for 2 other drawings. Then I re-opened one of these drawings and found I had double dimension objects. So, what actually happened was that they were there, and I could not see them. All I have to do is save, re-open, and the dimensions are all there. The question is why this is happening.
