AutoCAD Forum
Dimensioning
9 REPLIES 9
Message 1 of 10
470 Views, 9 Replies
Dimensioning
After picking both extension line origins I cant get a dynamic dimension to show at the tool tip before I place it. There is only a red line that i can move around.
9 REPLIES 9
Message 2 of 10
rkmcswain
Can't think of anything that would cause this off the top of my head. Do dimensions work in other areas of this drawing and/or in other drawings?
It would help for us to see the problem using a Screencast.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 10
in reply to: rkmcswain
No, it doesn't work in any dwgs. To clarify the dimension does appear after I select a location. Also when I create an angular dim. it works as it used to.
And just upgraded from 16 to 18.
Message 4 of 10
rkmcswain
This is probably not it, but is DRAGMODE set to "AUTO"?
Message 5 of 10
pendean
What command are you using exactly? Copy/Paste from the command line to here please.
Do you have an add-on installed with your 2018?
And did you use the migration tool to move your content from 2016 to 2018?
Message 6 of 10
in reply to: pendean
 Command: _ampowerdim
Specify first extension line origin or
[Linear/Angular/Radial/chaMfer/Baseline/Chain/Options/Update] <select object>:
Specify second extension line origin:
Specify dimension line location or
[Horizontal/Vertical/Aligned/Rotated/Placement options]:
[Linear/Angular/Radial/chaMfer/Baseline/Chain/Options/Update] <select object>: *Cancel*
Command cancelled
Command: *Cancel*
Message 7 of 10
It is set to Auto
Message 8 of 10
yes we do have a Pdm package called adept. And I'm not sure if the migration tool was used.
Message 9 of 10
rkmcswain
Ah..... that is a command from AutoCAD Mechanical, not AutoCAD. This is why we need images and screencasts, etc. Perhaps someone in the AutoCAD Mechanical forum would know, or perhaps someone has already run across this issue and solved it?
Tags (1)
Message 10 of 10
pendean
You are in the wrong forum... .
AutoCAD Inside the Factory
