Question:
I have changed the units to read architectural - feet, inches.
I am able to draw in feet, inches... however when i go to dimension drawing it defaults back to decimal.
Any ideas how i can maintain the dimensioning to architectural.
hi changing the units will only change the drawing units however you should set up also a dimension in ft or inch in the dimension manager and set it to current before dimensioning you drawing
type DIMSTYLE <enter>, select the default style or create new and set it as default, on the "Primary Units" tab change decimal to architectural, set the precision, ok and close.
