Dimensioning 3d Solid Objects
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi all
Working in 3d in AutoCAD for the 1st time in 3 years, all 3d in Inventor last 3 years.
How do you all dimension your 3d solid models.
Inventor was no problem, you projected your view to a layout and dimensioned that view as if it was a 2d
(which in effect it was-it was a 2d projection of your chosen 3d orientation.
In autocad I am rotating my view to an orthographic view using the face of the view cube.
Then I am dimensioning in paper space.
The trouble is, if you adjust the position of the model in the viewport, the dimensions don't move
and you have to dimension again.
I have never done it like this before
When in 2d in autocad I have always dimensioned in model space using annotative scaling.
This way the dimensions are always attached to the model wherever you move it.
What is the best practice here as done by all you continuous 3d autocad users?
Mike Kovacik
AutoCAD /Inventor 2d/3d draughtsman
AutoCAD 2018
Joburg, South Africa
Alfred.NESWADBA
please look to that thread, same question, >>>click<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
MikeKovacik4928
Thanks Alfred
That looks like it could be the solution
Will look at that later this evening or tomorrow evening.
I am rushing to finish a drawing for work tomorrow and will continue with my current
method of dimensioning in paper space.
Mike
PS
I am doing this because I have been FORCED at work to go from autocad to inventor for standard projects.
I am still using Inventor, however  for manufacturing drawings
In my private capacity as freelancer I will NEVER do any 3d solid modelling in autocad I will ALWAYS use Inventor.
I will only use autocad for 2d work
MikeKovacik4928
Sorry meant to say
I am doing this because I have been FORCED at work to go from inventor to autocad for standard projects
