- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having to place cross dimensions to a four sided shape polyline. When setting up the dimension styles I can set up text placement to the left or right but does not work out all of the time. For these instances I would have to manually move the dimensions to desired locations along the dimension line. With that exception, I would like to use fine tuning option to place the text manually, which is much effective and time saving; but it would ask for text placement before all of the dimension lines have been set. This causes issues because I want to have the cross dimensions set along the corners and this is impossible without snapping to the corners, which then places the text at the picked corner.
Is there a way to fine tune and place the text manually after all of the dimension lines have been set?
