Message 1 of 11
09:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I work with shop dwgs and have to do BOM's all the time. We want to use the fields option in the table for the dimensions of the material. The problem that we are having is the text in the table is not matching the text in the dimensions. I have set the stacking in the dwging to be horizontal but when I set the field in the table it converts it to diagonal. How do I make the dimension text in the field stack horizontal so they match?
Please see attachment, the clouded areas. I can't change the dimension stacking to diagonal it has to stay horizontal.
Thank you for your help,
Rebecca Donat
