Dimension text dimgap with alt dimension below
Message 1 of 8
AutoCAD 2016
I'm trying to do metric and imperial dimensions with the stacked fractions below.  When I grip edit the locations the fraction moves into the leader part of the dimesion.  The only grip edit that works is center vertically but you get a short leader.
Replies (7)
Message 2 of 8
Emmsleys
@Anonymous Could you please post a sample drawing? Is this a fairly new issue with AutoCAD 2016?
Sarah Emmsley
Technical Support Specialist
Message 3 of 8
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
1) It could be a bug ! ... But please post a DWG as asked Autodesk ...
2) Have you installed the SP1 for ACAD 2016 ?
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2016-service-...
Regards, Patrice (I am not an Autodesk Advisor)
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 8
Thanks for everyones interest.  Here is the sample drawing y'all requested.
Message 5 of 8
No I haven't installed it yet I will ask our CAD Administrator to do it and will let you know if it fixes it.  Thanks for your help.
Message 6 of 8
I've installed AutoCAD 2016 SP1, I didn't notice any change when having to move dimensions around.
Message 7 of 8
steve216586
To fix this issue, you must do one of two things:
1. Change DIMGAP to adjust for the additional text height that your stacked dimension affords.
2. Change the Fraction Height Scale in the Dimension Manager inside the Text tab.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 8 of 8
Thanks I've tried your sugestions, and
I increased from 1.5875 up to 4.0 without any success in regards to the alternate stacked fraction.
The only way I could change the Fraction Height Scale (grayed out) was to change my primary units from Decimal to Architectual then on the text tab I changed it from 1 through .5 before it worked but the fraction is so much smaller.
I did find a work around that I'll probably use. I changed my alternate Units to Architectural instead of
Architectural Stacked.  It does take up more room for small dimensions.  I wish you could do diagional stacked fractions like in MText.
