Hi @Jkane2022 , Welcome to Autodesk Community Forums
As I can see you want to import/export Dimension style to save time
Yes you can do by Express tools tab, under Dimension pull down you can see "Import style" and "Export style"
or by using DIMIM or DIMEX command to import/export dimension style respectively.
Refer to this forum thread for reference
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Hi @Jkane2022
I understand you need to have a default Dimension style whenever you create a new drawing:
1. Create your custom dimension style and set it as current then close the dimension style manager dialog box
2. Save the current drawing as a template (.dwt) with a new name to it.
3. Now, you can create a new drawing in which you have saved your custom dimension styles, and when you check the dimension style manager you can see the dimension style you have created would be already set as default.
Hi there...
I have just today switched from 2025 to 2026 Auto CAD....I have ALWAYS had a Format tab in my ribbon...where is it now and how do I access it? I require it to access so many things!
format tab? What does this relate to the topic (dimstyle)?
BTW: AutoCAD ribbon never had a Format tab (or is it a special of MAC version, where the UI is named wrongly as ribbon too?)
But Autocad have a MENU "Format" since decades..
What is turned off by default, also in 2025
MENUBAR<enter>1<enter>
Search in www for a picture where you can see that "Format",
Upload your current screenshot and the found www picture.
This way we can see the real problem and how to fix it
Sebastian
sorry to sound rude, perhaps because english isn't my native language!?
Would you please attach a Screenshot of the whole program window where we can see that ribbon tab?
Thanks in advance, I like to learn (where I was wrong)
Sebastian
Sebastian
Offtopic:
>"I have spent to have this program, I expect customer service to be a hell of a lot better
than this!"
Then you have to ask your customer service and try your luck.
>"I would like to be transferred to another agent."
Agent?
Hey,
you are posting in a PUBLIC USER FORUM,
all people can read what you/we write here!
I am not an Agent, I am a User like you and 100000 others here and spent my time trying to help you!
LG Sebastian
Sebastian
Nothing attached..
(Mistake, or are you writing by eMail? That doesn't work, you have to come to the Forum direct: https://forums.autodesk.com/t5/autocad-forum/dimension-style/m-p/13851957#M355867
This is the only Format I know:
this is a Menu. To see menus you need to turn on Menubar, as I point to in my first post.
I am wondering about the format ribbon tab and waiting for your screenshot (thanks).
Sebastian
