Hi All,
I have started using AutoCAD 2024 and since using this version I find when I'm adding dimensions to my paper space it seems to pick up every snap point around and freeze for 10/15 seconds. Never done this before and I tried just leaving on a couple of snap point like end point and centre point but it still happens all the time and takes a life time to do a big design.
its like when you use press pull command and it looks for every available shape before hand.
Any help is much appreciated.
@Lee_plunkett
Hello & welcome! Can you please share some system specs? Actually I'm hoping one of or experts knows a quick sysvar that you can toggle to address this. 🙂
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Have you installed the 2024.1.4 Update yet? ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD2024.
Then...
@Lee_plunkett Hello, do you still need help with this question?
Chris Benner
