dimension settings
dimension settings
MRF80
dimension settings
MRF80
Hi all,
Having some issues with dimension setup. Main issue being the dim text and dim arrows that are showing the size of the walls, are appearing directly on the same plane as the room sizes. I’ve fiddled with many settings, but can’t solve the issue? Please see the attached cad file where you can see the issue with the dimensions (shown on top edge of home). I’ve also attached a PDF of a drawing which shows how I want the dims to look, with the smaller dimension positioning itself just above, so not covering the other dim texts.  I’m presuming there is a setting to do this rather than having to move each dimension manually to tidy it up?
Kind regards
Matthew
Accepted solutions (3)
Kent1Cooper
DIMCONTINUE will do it this way, if that works for you:
Kent Cooper, AIA
MRF80
Hi Kent1Cooper,
Thanks for taking time out to reply!
It's not so much the continuing of the dimension. I already use that function with no issue.
Its more to do with trying to force dimension text and arrows to not overlay one another. Happens when there are smaller room sizes so dimensions are closer together. I've solved the issue for the dimension that dictates the wall thickness, I just had the initial position centralised during the initial placement. Just wonderd if there is some kind of override that stops dimension text and arrows going on top of each other. The dimensions shown on the PDF I attached were done automatically in a years old bit of CAD software, so surprised that no function similar exists in autocad??
pendean
Community Legend
Community Legend
DIMCONTINUE will move most of the conflicting dimensions for you automatically as @Kent1Cooper shows in his screenshot above.
Your first dimension will always be in the way unfortunately unless you set your DIMSTYLE to always let you manually place the dimtext.
MRF80
Thank you both for your help!  I appreciate it.
degavath_varun_apd25
Community Visitor
Community Visitor
DIMENSIONS ARE NOT SHOWING TO ME HOW TO THAT IF I SELECT THE COMMAND BUT COMMOND NOT PROPER WORKING EITHER IM NOT USING PROPER PLEASE GUIDE ABOUT THE DIMENSIONS
Kent1Cooper
@degavath_varun_apd25 wrote:
.... COMMOND NOT PROPER WORKING ....
That is never enough information.  Which command(s) are you using?  What does it do differently from what you expect?  Does it do something but not all you expect?  How far does it get?  Are there any messages?  Have you read about the commands thoroughly in Help?  Can you post some images or a little video of what you are doing?  Etc.
Kent Cooper, AIA
