1. copy-paste the certain part.
2. select the certain part and use "scale" command.
follow the instructions.
3. set the dimension scale-factor to 0.5 by typing "DIMLFAC"
4. Dimension the certain part.
OR
4.2 Copy the part "and your existing dimensions" and scale them.
4.3 make one dimension in scale-factor to 0.5
4.4 Match the properties of the dimension with scalefactor 0.5 to the normal scaled dimensions, by using "MATCH PROPHERTIES"
WOLA!
@Anonymouswrote:
I made a drawing and would like to blow up a certain part of it for a better view. I found that you can apply a scale factor if you copy and paste, however when I go to place it or type in an insertion point, it will just paste at original scale at 0,0.
I then thought that if I were to just draw it at twice the size, I could just scale down the dimension. I'm not able to get that to work either.
Is there a way to get either of these options to work or even a better way to go about doing this?
Thank you!
Thank you!
