Dimension problem
Dimension problem
Dimension problem
I can't use dimension properly because it's set to a specific measurement and doesn't follow my cursor. What should I do? problema autocad.png
pendean
Community Legend
Community Legend
Post your DWG file, walk us through it step by step how to repeat the issue.
ok
imadHabash
turn OFF your Dynamic Input ( F12 ) , any changes now ?
Imad Habash
Nope, it's a orthomode problem, but only in this dwg file. When I have it on, I got the problem in the above ss, when I turn it off, dimension line comes back to normal and follow my cursor without being to a specific length.
j.palmeL29YX
@pendean asked: "walk us through it step by step how to repeat the issue".
Which command do you use?
Which AutoCAD version do you use? (any vertcal prodict?).
We need more information ...
Jürgen Palme
pendean
Community Legend
Community Legend
Set both UCS and PLAN commands to WORLD, that should take care of it: otherwise post your DWG file for all of us to have a look, or fix your file by INSERTing it into a blank template without this issue in place.
