Dimension/ OSNAP Settings
desjacobs
Message 1 of 10
desjacobs
I am unable to select the 'midpoint' of the Dimensions with the current settings in AutoCAD 2024, this has never occurred before.  All other items/ objects have ability of 'midpoints' being selected.  Any solutions or ideas please?
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Greetings @desjacobs
Midpoint of dimensions? Show us what you mean, even if you have to fudge it please.
Message 3 of 10
Kent1Cooper
You can Osnap to lots of MIDpoints in Dimensions:
If you mean the point midway between the Dimension's definition points, use M2P/MTP Osnap between the NODe Osnaps on the definition points.  Type in the M2P or MTP, or Ctrl+right-click or Shift+right-click and pick it:
Kent Cooper, AIA
Message 4 of 10
desjacobs
It would appear that none of the OSNAP Settings are working for the Dimensions.  All other items are working as required, any ideas?  Thanks in advance.
Message 5 of 10
cadffm
are you really sure you are using a product named AutoCAD 2024?
Please share your ABOUT dialog.
Sebastian
Message 6 of 10
desjacobs
Hi Sebastian, yes AutoCAD 2024.
I am not familiar how to share the 'About DIALOG'...?
Message 7 of 10
cadffm
Start command ABOUT
Make a screenshot: https://support.microsoft.com/en-us/windows/use-snipping-tool-to-capture-screenshots-00246869-1843-6...
Paste or attach [Browse] your screenshot.
>>"AutoCAD 2024"
Okay. Is it a problem in every drawing, also in this drawing (attached)  ?
Sebastian
Message 8 of 10
Valentin_CAD
@desjacobs ,
Try these suggestions:
If using AutoCAD 2024 Mechanical:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 9 of 10
desjacobs
Thank you Valentin, that seems to have done the trick.👏
Message 10 of 10
cadffm
What exactly? Good to know for other Threads in the future.
The links are
1. about another Software
2. Disabled osnaps, so it won't work with any objecttype, not only dimensions.
Sebastian
