Dimension/ OSNAP Settings
desjacobs
desjacobs
I am unable to select the 'midpoint' of the Dimensions with the current settings in AutoCAD 2024, this has never occurred before.  All other items/ objects have ability of 'midpoints' being selected.  Any solutions or ideas please?
0 Me gusta
Responder
Soluciones aceptadas (1)
758 Vistas
9 Respuestas
Respuestas (9)
pendean
Community Legend
Community Legend
Greetings @desjacobs
Midpoint of dimensions? Show us what you mean, even if you have to fudge it please.
0 Me gusta
Kent1Cooper
You can Osnap to lots of MIDpoints in Dimensions:
If you mean the point midway between the Dimension's definition points, use M2P/MTP Osnap between the NODe Osnaps on the definition points.  Type in the M2P or MTP, or Ctrl+right-click or Shift+right-click and pick it:
Kent Cooper, AIA
0 Me gusta
desjacobs
It would appear that none of the OSNAP Settings are working for the Dimensions.  All other items are working as required, any ideas?  Thanks in advance.
0 Me gusta
cadffm
are you really sure you are using a product named AutoCAD 2024?
Please share your ABOUT dialog.
Sebastian
0 Me gusta
desjacobs
Hi Sebastian, yes AutoCAD 2024.
I am not familiar how to share the 'About DIALOG'...?
0 Me gusta
cadffm
Start command ABOUT
Make a screenshot: https://support.microsoft.com/en-us/windows/use-snipping-tool-to-capture-screenshots-00246869-1843-6...
Paste or attach [Browse] your screenshot.
>>"AutoCAD 2024"
Okay. Is it a problem in every drawing, also in this drawing (attached)  ?
Sebastian
0 Me gusta
Valentin-WSP
@desjacobs ,
Try these suggestions:
If using AutoCAD 2024 Mechanical:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
desjacobs
Solución aceptada
Thank you Valentin, that seems to have done the trick.:manos_aplaudiendo:
cadffm
What exactly? Good to know for other Threads in the future.
The links are
1. about another Software
2. Disabled osnaps, so it won't work with any objecttype, not only dimensions.
Sebastian
0 Me gusta
