Dimension lines not showing in render
Putting Dimension line in model workspace works fine, but when I do a rendering, there are only arrows and dim text. how do i get the lines shown?
  I feel like the arrows doesn't do any good, when there are no lines.
What do I do?
pendean
Community Legend
Community Legend
You want 2D dimensions to show up in 3D renderings? Move them above the plane you have them on so they do not get swallowed up.
I think I understand what you mean.
they are already 0.5 mm above the wood 3D box below.
I tried removing the wooden box underneath, so there was nothing below, but got same result.
Did I misunderstand you?
leeminardi
Explode the dimension lines and then change the weight value from 0 to a small value (e.g., 0.01) and render.
Note, your part is over dimensioned!!  A big no-no.  Delete one of the following dimensions 25, or 35, or 60.  Having all 3 causes a conflict when tolerances are considered.  You only need 2 of them to construct the part.
lee.minardi
