Dimension lines have spaces in lines
maryhanley
Message 1 of 11
maryhanley
my dimensions are on tight spaces , so the the fit option is set to 'move text, add leader'. But why is there a space in the leader. all linetypes used are continuous. layers are the same . see attached screenshot for reference. even when I get a extension line that is solid (like I want it)  and then I do a match properties- it goes back to dashed.
Replies (10)
Message 2 of 11
imadHabash
Would you please attache here a CAD file for testing?
Imad Habash
Message 3 of 11
maryhanley
Here's the file.
Message 4 of 11
pendean
Community Legend
Community Legend
@maryhanley wrote:
Here's the file.
Nothing attached: you cannot reply to an email if that is what you tried, you must visit the website and tap the REPLY button to add files. HTH
Message 5 of 11
maryhanley
file is attached
Message 6 of 11
Kent1Cooper
I think it has something to do with the definition of the _Oblique arrowhead Block, but I can't pin it down.  Drag the text part farther away, and the gap remains where it is and the same size, and no other gaps appear, so it's not a linetype issue.
Kent Cooper, AIA
Message 7 of 11
pendean
Community Legend
Community Legend
Thanks for the file: looks like you are up against the leader not wanting to interfere with the dimension extension line
As noted by @Kent1Cooper using any other tickmark removes the limitation, but both core 'tick' blocks do what you see in your files.
Message 8 of 11
maryhanley
another observation- the gap size always stays the same size as the arrow, so if I change the arrow size to 1" the gap changes to 1" (but no arrow keeps a gap?!?). And the gap goes away with certain arrow types , but that does not help me any since we normally use a arch tick or oblique- and both of those apply the gap.
Message 9 of 11
maryhanley
any idea of a setting that would change that ?
Message 10 of 11
pendean
Community Legend
Community Legend
Have found no setting yet, seems to be "built-in".
Message 11 of 11
Kent1Cooper
You may get something from >this<.  It's about overcoming the limitation on how close the text is allowed to get to the arrow, but I assume the gap you are seeing is at least related to what that Message refers to as the tail of the arrow, of the same length as the arrow though not part of the Block, creating that limit.  It looks like with the oblique/tick Blocks that limit doesn't get filled in with tail as it does with other arrows.  I don't know of a way around it in this case, but I think using the approach there can reduce the gap -- maybe go further, and define a Block 4 times as big and use it at a quarter of the ordinary-Block size in the Dimension Style [or even more extreme...].
Kent Cooper, AIA
