As a preface, I am still very much a beginner, my only real CAD experience so far is in making 2D designs for the plasma CNC at work.
I am attempting my first foray into dimensioning from a model instead of just making all the faces in 2D and dimensioning separately as on a sketchpad, I am trying to to add dimensions for holes to be drilled in a box, however I am finding that my dimension lines are going "out" along my y axis instead of "up" the z axis to be actually able to view them when looking at the relevant model face,
I've attached a screenshot showing a red dot in the circle id like to be dimensioning to the top right corner of the model, with the dimension line instead originating from the bottom right corner of the model, as well as the dwg, please ignore the size of the dimension text and the fact I'm doing them in the model instead of paper space as viewports/paper is space in general is proving even more of a headache at my current level with this model.
Any ideas or settings to correct to be able to rectify this issue would be greatly appreciated thank you
Solved by Patchy. Go to Solution.
