Hi All,
Got an issue with the dimensions on a drawing. When I turn the layer back on that has the dimensions on they have all become wildly out of position. I have not moved anything in the drawing and have just been switching the layer on an off to add other details. I have seen on here about associative dimensions but if I change the dimensions nothing changes.
Screenshot attached:
Thanks for the reply.
Unfortunately I did not generate the original drawing and personally do not use XREF so am not aware if there are any. Doubtful. I definitely have not moved any elements of the drawing?
Clearly AutoCad uses layers differently to other programmes that I use. I'll have to investigate FREEZE/THAW Does it keep the content visible? Not much use to me if it does.
If that's a dire business need for you, it might be a good time to consider a change. AutoCAD has not changed much in 40-ish years now.
@janken25 wrote:
...I'll have to investigate FREEZE/THAW Does it keep the content visible? Not much use to me if it does.
It took more time to type your reply than to test it out my friend.
@janken25 wrote:
...I definitely have not moved any elements of the drawing?...
Someone did at some point, or made other changes to the DWG file: nothing ever just moves on it's own for no reason at all.
Best wishes.
