dimension inputs not showing up anymore
When I go to make a line and I want it to be 1" long. I first click, then drag in the direction i want, then USUALLY when I type how long I want it to be, a little box shows up showing me what I typed before I click enter to create the line.
AutoCAD, having a mind of its own, switched that setting off on me sometime while I was sleeping. Ho do I turn that back on. Everywhere on google said Dynamic input, but that was only half of the problem. It only shows as you pull the line, not when I type something in.
SeeMSixty7
There should be a toggle in the lower part of the AutoCAD screen to toggle on and off Dynamic input. or you can use F12.
Good luck,
imadHabash
>>  It only shows as you pull the line, not when I type something in.  <<
i suggest to check Dynamic Input tab from DSETTINGS command.there you will find the settings that can serve your need.
Imad Habash
the function still works even without DYNMODE active, the input appears on the command line.
"Enable dimension input where possible" was the check box I needed!
Thanks you!
Much more efficient to see it on the screen where I am looking than on the command line at the bottom of the screen. Plus had it like this since the start so after doing something, I wait for it to pop up... then im like oh wait its just waiting for me now....
