dimension input doesn't work
eino_lahtinenY7EBS
Message 1 of 10
eino_lahtinenY7EBS
I have checked every settings of dimension and dynamic input. Toggling, DYNMODE or DYNPROMPT or anything else doesn't make this correct.
Basicly dynamic input works as usually but dimension input is gone.
Replies (9)
Message 2 of 10
imadHabash
Hi and welcome to AutoCAD Forum,
Enable Dimension input From  DSETTINGS >> Dynamic Input tab , any changes?
Imad Habash
Message 3 of 10
eino_lahtinenY7EBS
It is allready enalbed but i tried to set it off and on - still doesn't works
Message 4 of 10
imadHabash
Click on below image to see how by DIST command you can see the dimension, does that happened with you?
Try it in a new empty CAD drawing...
Imad Habash
Message 5 of 10
eino_lahtinenY7EBS
DIST works as usually, dimension input is that problem. Example if i start to stretch some vertex, CAD offers dynamic input (polar/cartesian, that doesn't matter) but no dimension input if I try it with Tab.
Message 6 of 10
Brock_Olly
Can you share a screenshot of what your cursor looks like ?
Message 7 of 10
pendean
Community Legend
Community Legend
Is the problem in ALL files, or just this one?
If in ALL files, did you restart your computer yet?
If still an issue, I'd appreciate a video of you in action using those tools, perhaps you are trying something that is not possible.
Message 8 of 10
eino_lahtinenY7EBS
I'm had this issue few months now and it's permanent and in any dwg-file.
Tallenne-20250115_091417.webm
Message 9 of 10
pendean
Community Legend
Community Legend
Do this
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
Or... Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Message 10 of 10
eino_lahtinenY7EBS
That reset settings works, thanks!
