Dimension in Paper space does not match what model is
Message 1 of 8
Running AutoCAD 2018. I've created a 3D model which is 1:1. When I bring it into paper space
and attempt to dimension it in a view port, my dimensions are off by a factor of 4. So what should be a 9.3 inch length is now showing as a 2.325 inch length.
I have tried changing scales in multiple places and nothing seems to work. What am I missing ?
Replies (7)
Message 2 of 8
chriscowgill7373
Can you provide a copy of your file, or some screenshots of what you are seeing?  It sounds like you might have a scale factor, but are also using DIMASSOC set to 2.  If you change it to 1, it may help.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
Message 3 of 8
Patchy
Go to Dimstyle and check the scale factor.
Message 4 of 8
I've attached my file for reference
Message 5 of 8
pendean
Community Legend
Community Legend
Your viewport has not scale, you have it set to a random setting: fix that first.
And is that the view/rotation you really want? What are you trying to print exactly, for what purpose?
Is your default active DIMSTYLE set the way you actually want it to appear?
Message 6 of 8
chriscowgill7373
as @pendean has stated, your drawing does not appear to be configured to be dimensioned.  The viewport scale is set to .1314.  You'll need to set that scale first and get your view positioned properly before you can dimension anything.  Your dimscale is already set at 1, and DIMASSOC is set to 2, so once your scale is set, you should get the dimensions you are looking for.  Also, if you are dimensioning an isometric view, you wont be able to use an aligned dimension, it doesnt seem to grab the right points to provide an accurate value at the angle.
Message 7 of 8
Sorry, I had not intended the layout to be my end look. I've attached another file. I shut down AutoCAD and restarted and created my views. After I dimension now, I get an incorrect dimension and a yellow square. If I click on it and reassociate the dimension is now correct. Really not sure what I did.
I need to send dimensioned drawings to a vendor to build the part.
Thanks for the help!
Message 8 of 8
chriscowgill7373
If you accidentally select a paperspace point for one of the two dimension points (such as the node for another dimension), you will get that result.  You have to make sure you are selecting the end points of your modelspace linework to get the associated dimension.  If you dont wish to use this option, you could change your dimension scale to 4 and DIMASSOC to 1 and then all of your dimensions will be 4 times what the paperspace distance is, but you dont have to be as careful about what you snap to.
