Dimension Help
Dimension Help
gottfriedjoseph01
Dimension Help
gottfriedjoseph01
I've been looking ways to quickly dimension the blocks in my drawing. Similar to the QDIM command except I need it for the blocks in the drawing Any clues on how to do something similar with the pile blocks in this drawing. Thank you in advance.
paullimapa
why not edit the block and then add qdim there?
or are you referring to dimensioning from one pile to another?
provide examples so we know what dimensions you would like to see
Paul Li
IT Specialist
@The Office
imadHabash
@gottfriedjoseph01
I'll give you a good idea how to use QDIM command.
  • Draw two short lines on their own layer while you're in Block definition for the pile block [Bedit command].
  • By QSELECT command 👇 take a copy from all pile block.[Click on below image to enlarge]
  • Now, take a copy from all of those blocks only aside then Explode them.
  • as shown in below image 👇 Erase all blocks after exploding and just keep all of two short lines.
  • Now, You can use QDIM command to all of your blocks from center to center (as I understand).
  • After that you can delete the two short lines from your block by BEDIT command again.
Click on below image to enlarge. [Pay attention to the commands used]
This quick and safe tricky way allows you to get what you want without any problems.
All the best... 👍
Imad Habash
lauri_barnhart
Hello @gottfriedjoseph01, thanks for posting in the community!
Did the response provided by @imadHabash help answer your question? Did you also notice the additional questions posed by @paullimapa?
If yes, please mark the reply as the accepted solution.
This helps other users benefit from the information.
If not, please provide an update so other members can jump in with further suggestions.
Thanks!
Lauri | Community Manager
gottfriedjoseph01
Not exactly what I was looking for. I fear that the idea I have just isn't possible with autocad. Thank you for solution though.
