Announcements
Dimension Disassociated annotations
hamoodpg
hamoodpg
I dont know what happened but I was working on my plan and taking dimension suddenly  I got the error only on that specific Dimension, can you tell me how to remove it ?
cadffm
The dimension is not or not fully associated with objects (check the properties palette information).
Read more about ANNOMONITOR
Sebastian
hamoodpg
 what do I check exactly ?
cadffm
Select the dimension object
[CTRL]+[1]
"Associative"
YES means, it is associated with other objects. Move the other object (a line you added the dimension)
and the dimension will following the new objects size or position.
http://help.autodesk.com/view/ACD/2020/ENU/?guid=GUID-8B7E8C96-C30D-409E-881E-7942871E80DA
Sebastian
vinodkl
set ANNOMONTOR to "0"
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
