Dimension Automatically layer assigning lisp
Message 1 of 8
Dear all,
I am a beginner in auto lisp program and i have made one lisp for dimension assigning to layer automatically but i need after commands end current layer should back to zero. If anyone expert kindly please help me.
My lisp code is following below:
(defun c:dli()
(command "._layer" "_n" "Z-Dimentions" "_c" "1" "Z-Z002-S-Dimentions" "_th" "Z-Dimentions" "_on" "Z-Dimentions" "_s" "Z-Dimentions" "")
(initdia)
(vl-cmdf "._dimlinear")
(setvar "clayer" 0)
(princ)
Looking forward your kind support and help in this
Accepted solutions (4)
Replies (7)
Message 2 of 8
vinodkl
Hi @Anonymous
Here is a similar lisp which does the work which you are asking for🙂
http://www.lee-mac.com/layerdirector.html
You can modify the lisp(change "dimension" layer name) to suit your needs. Read the description completely to know how the lisp works.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 8
cadffm
CLAYER is a variable for the current Layer,
Layernames are STRINGs , but you trying to feed CLAYER with a NUMBER.
The Layername is "0" and not 0
(setvar "CLAYER" "0")
But better is to store the last current layer (setvar oldclayer (getvar "clayer"))
and at the and (setvar "clayer" oldclayer)
And for both layers (clayer), make sure the layer is THAWed
For non-programming solution:
a) Draw dimlinear on your layer, drag the dimlinear to yout toolpalette [CTRL]+[3]
b) Simple use: Setvar DIMLAYER
offtopic
For Lisp questions, please use the LISP board
If you have error messages, please add them to your initial post
Sebastian
Message 4 of 8
ВeekeeCZ
What version of AutoCAD you have?
Does it have DIMLAYER variable?
Message 5 of 8
ВeekeeCZ
Here is a basic approach for such a routine. Commented.
(defun c:DLi ( / *error* lay)    ; *error* MUST alway be localized, all the rest should be
  (defun *error* (errmsg)   ; must be localized!
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if lay (setvar 'clayer lay)) ; restore layer in case of error
    (princ))
  (setq lay (getvar 'clayer))
  (command "._-layer" "_t" "Z-Dimentions" "_make" "Z-Dimentions" "_c" "1" "Z-Z002-S-Dimentions" "")  ; MAKE options makes layer on and current. also creates new if doesn't exist
  ; (initdia) useless, dimlinear has no dialog
  (command "._dimlinear")
  (while (> (getvar 'cmdactive) 0) (command pause))  ;; stay within command until done.
  (setvar 'clayer lay) ; restore layer
(princ)
Message 6 of 8
Thank you for your kind support
Message 7 of 8
How to add single lisp command  multiple defun c: function command
for example:
(defun c:DIMX(dimension) if(not(defun c:DIMY)
Message 8 of 8
ВeekeeCZ
Not really sure what you're after, but you can do something like this.
(defun c:dimxy (/ tmp)
  (initget "Vertical")
  (setq tmp (getkword "Would you like make a horizontal dimension? [no, Vertical] : "))
  (if tmp
    (c:dimx)
    (c:dimy))
  (princ)
(defun c:dimx ()
  ;something ...
(defun c:dimy ()
  ;something ...
You need to explain better....
