AutoCAD Forum
DIMALIGNED settings appearing as too large
2 REPLIES 2
962 Views, 2 Replies
I am trying to use the DIMALIGNED command with 0.08 text and arrow size. I set these in the DIMSTYLE window. When I used DIMALIGNED command, the text and arrows come out 10 times as large as I want them. Help?
Tags (2)
2 REPLIES 2
miledrizk
Maybe after you set up the Arrows and Text dimensions you forgot to click Set Current
Probably a different style was in use, other than the one you modified
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
imadHabash
Hi and Welcome to AutoCAD Forum,
Yes ... as mentioned above please make sure that your needed dim style is set to current .
Imad Habash
AutoCAD Inside the Factory
