DIM Layer Default
DIM Layer Default
AWVGPeyton
Message 1 of 11
DIM Layer Default
AWVGPeyton
Is there a way to set dimensions to be on my DIM layer?
I have changed it to DIM layer in the Dimension Ribbon and then saved my template file.
Yet when I start a new drawing it changes back to "Use Current".
This may be a newbie question.
Replies (10)
Message 2 of 11
user181
Hi @AWVGPeyton  Change the value of the DIMLAYER variable to the layer you want your dimensions on.
Message 3 of 11
AWVGPeyton
That only changes it for the current drawing. When I start a new one it goes back to "Use Current".
Is there a way that to change it and for every drawing I create the default will be my "DIM" layer?
Message 4 of 11
user181
You need to set it in your template and start new drawings from your template.
Message 5 of 11
AWVGPeyton
I did set it in my template and saved the template.
It still defaults to "Use Current".
Confused.
Message 6 of 11
user181
How are you starting a new drawing?  Type NEW and browse to your template and open.
Message 7 of 11
AWVGPeyton
I hit the new drawing button and it points to my template.
When my template opens a new drawing it is set to "Use Current"
When I open the actual .DWT file it is set to "DIM", like I want.
Message 8 of 11
S.Faris
Which version of Autocad are you using?
SALMANUL FARIS
Message 9 of 11
AWVGPeyton
AutoCAD2019
Message 10 of 11
user181
Check in your OPTIONS on the files tab > template settings >Default template file name for QNEW is pathed to the template you are modifying.
Message 11 of 11
AWVGPeyton
That was the problem.
Problem fixed!
Thanks!
This has been driving me bonkers for awhile.
