Different scale baseview between perspective and front
jens.vanheckeLDNK7
Observer Observer
jens.vanheckeLDNK7
Observer
Observer
Wen placing a drawing in pspace with the base option it occours to me that the dimensions of the perspective aren't correct.
Does someone know were the settings are to change the dimension line when you measure on a isometric view?
Thx!
Jens
ben.saa
Autodesk Support
Autodesk Support
The isometric view is considered to be a projected view, isn't it?
in this case, the dimensions will be different
Do you have an example to show?
jens.vanheckeLDNK7
Observer
Observer
Indeed. You can see it on the drawing. In our pspace A3 liggend you can see that the measurement isn't correct. It says 882mm instead of 1020.
It was a question of my student yesterday. I think this couldn't be resolved easily. I also think placing a dimension on a perspective isn't necessary al all.
But if there is a easy solution. It would come in handy !
