Batch Changing Text Color that is no longer ''By Layer''
dany_rochefort
dany_rochefort
Good morning, i have a bunch of text that is on the correct layer, but the color has been manually changed and is no longer ''by layer''.  I am trying to ''batch change'' the text color back to ''by layer'' in 1 move.
Is there any way to do this ? Or must i manullay go thru it all ? Thanks in advance...
JCKRU47
With the provided information you could right click on the text and use select similar to highlight all text, then change them from varies to by layer. More like two steps, but should be quick.
imadHabash
Try SETBYLAYER (Command) . >> Click <<
Imad Habash
cadffm
Search for StripMText
Sebastian
cadffm
MText: Stripmtext
Attributes on Blockreference: ATTSYNC
Sebastian
user181
You can also use the .QSELECT command and select options: Mtext or Text, color, <> Not Equal,  Bylayer.
dany_rochefort
OMG, that Lisp command is amazing....  Thank you!
