Different computer plotting different colors to PDF
I am currently experiencing an issue where my PC and a coworker's PC are plotting different colors to PDF even though the same plot style is being used. Both PCs are identical, running Windows 10, and are running on the same network. Has anyone run into this issue before?
jayhar
Hi
1.  update Adobe Reader.
2. Check the settings in the DWG to PDF.pc3
https://forums.autodesk.com/t5/autocad-forum/print-to-pdf-colors-incorrect/m-p/6603471#M144727
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
imadHabash
>> .... my PC and a coworker's PC are plotting different colors
from one of your PC type in   _plottermanager command and delete the plotter that you use ( DWG To PDF.pc3 ) then copy it again from the other PC , any changes ?
Imad Habash
