Diameter Dimensioning Issue
Hello dear members,
My Dia. Dim isn't rotatable, when I put a Dia. Dim it is movless and don't rotate in time of putting it in the dwg.
I've tried many options in ddim, but don't fix it.
Any opinion helps, appreciate.
The DIMDIA is initially placed by your selection point, once placed you can grip drag it anywhere you like.
Hey,
Till I was working on 2015 the diameter dimension was rotatable when putting in the dwg.
but now in 2017 upgraded for me, it is as same as you said.
Did they change in the newer version?
DIMTMOVE or
imadHabash
as mentioned above,after you finish the command you can use grips to easily reposition the resulting diameter dimension.
Imad Habash
