Dialog box missing
Dialog box missing
McCray.jensenPEYLG
Observer Observer
Dialog box missing
McCray.jensenPEYLG
Observer
Observer
It seems one of my dialog boxes is missing. While trying to add a visibility state no dialog box shows up and it will not allow to me add additional visibility states.
Ive tried going into settings > options > system > hidden message settings, but that didnt seem to help.
Ive reset my computer and autocad several times.
vinodkl
Hi @McCray.jensenPEYLG
I assume the visibility dialog box is stuck in another screen which is not visible.  Try this: after clicking on visibility states
  • Press ALT+Spacebar key (let go)
  • Press M key (which means move the current window)
  • Press either the left or right arrow key (on keyboard)
  • Move the mouse. (If you have a window or dialog off the screen it will trap itself to the mouse pointer thus allowing you to place the window on the correct monitor)
Hope this helps 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
McCray.jensenPEYLG
Observer
Observer
I had looked all over both my monitors, but yes, this was the problem. Thank you very much!
mevansPP3JC
Community Visitor
Community Visitor
I currently have this problem with the rename & renumber dialog box on sheet set. I have followed these steps a few times and still do not have success, it seems to be attaching to an invisible dialog box that I can move around but do not see regardless of location or screen
I know a few folks in my office that have had this problem with various dialog boxes, it usually involves reinstaling CAD and resetting this profiles which is...annoying
acruz
Thanks! This helps.
I have to resize my AutoCAD window to smaller size first.
jin_zhangL9R8B
alt-spacerbar+M+ arrow doesn't work for me. i just disconnect outside monitors with laptop. then the dialog shows. then connect outside monitors again.
