AutoCAD Forum
Dialog box missing for AutoCAD 2016 with windows 10
4 REPLIES 4
1147 Views, 4 Replies
I recently upgraded my computer from windows xp to windows 10 and installed AutoCAD 2016.  However, there is a feature with AutoCAD 2013 that appears to be missing in 2016.  When I click on a line in 2013 a dialog box pops up showing several features of that line which can be changed with the dialog box.  See attached AutoCAD 2013 (1).jpg.  I clicked on the same line for the same drawing now imported into 2016 and the dialog box does not show up.  See attached AutoCAD 2016.PNG.  Is there a default setting that I need to change to have this dialog box automatically show up when cliking on a line or feature?
4 REPLIES 4
That would be your quick properties, you need to add it to your CUI
pendean
QPM is turned off in 2016: turn it on. Look up QUICKPROPERTIES in HELP in 2016 for details.
in reply to: pendean
Thank you. I turned QPM on and it now works.
Thank you. I turned on the QPM and it now works
Technology Administrators
