DGN Viewer
DGN Viewer
MarkFitz
DGN Viewer
MarkFitz
A little different question from the norm this time.
I have the DWF viewer for ACAD (AutoCAD Design Review), which has a blanked out section to select DGN file types.  Does this viewer work with DGN file types?   I downloaded the viewer, but now I think it says it needs extra software to view anything more.
Does Design Review show DGN as well as DWF types, and if so, what do I need to do to obtain it (I have the initial basic download).  And this is so my company can install it, so I need the relevant information regarding cost or licensing, etc.
Any takers?   I may be in the wrong place to ask such questions, in which case, can someone please point me in a better direction.
Many thanks,
Mark
Patchy
MarkFitz
*tips hat*  Thanking you, kind Sir.  That's where I was originally, I was asked to see if  there was an alternative.
I tried B-View. Wouldn't even startup. Was crashing on startup, with Event Viewer Errors:
Faulting application name: BentleyView.exe, version: 10.15.0.75, time stamp: 0x5fbf3494
Faulting module name: InProcessClient64.dll, version: 4.4.3.149, time stamp: 0x5f74682b
Exception code: 0xc0000005
Fault offset: 0x000000000004cd7a
Faulting process id: 0x3fbc
Faulting application start time: 0x01d73075f48d9b81
Faulting application path: C:\Program Files\Bentley\Bentley View CONNECT Edition\BentleyView\BentleyView.exe
Faulting module path: C:\Program Files\SentinelOne\Sentinel Agent 4.4.3.149\InProcessClient64.dll
Report Id: 78d6565f-f264-45a6-b5bd-bf029f9f564e
Faulting package full name:
Faulting package-relative application ID:
AND ...
Application: BentleyView.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at <Module>.wWinMainCRTStartup()
pendean
Community Legend
Community Legend
No one here supports Bentley software products: try their support forums over there instead https://communities.bentley.com/products/
