- Mute
- Permalink
- Report
I have researched this in many different forums and can't find a solution that works. We have an HP DesignJet 500 42" plotter (not PS, not HP-GL). I can plot to it from Autocad 2014, but not 2016. When I try to select the plotter in 2016 it reverts to Plotter: None. (Using Win 10 64 bit). I'm also able to plot to it using other programs (like Adobe).
Apparently ACAD 2016 only recognizes the driver v 8.10, and not older drivers. Here's the problem: When I download the 8.10 driver from HP (like other solutions suggest):
a) HPDJ500wx64pclen (found under Win 8 on HP.com) says on the website that it is 8.10, but when I install it actually says it's v. 6.07 (in the About section and the Readme file)
b) HPDJ510wx64glen (found under Win10) but it only applies to HP 500 HP-GL/2 & RTL. So when I install the driver there isn't an option for a plain HP 500 (just PS, HP-GL, plus, etc). I tried installing all the options. ACAD then recognizes the printer in the plot dialog but the printer gives an Error 61:05 (I have the most recent printer firmware installed).
It seems that in order for AutoCad 2016 to print to the HP500 it needs driver version 8.10, however there is not an 8.10 for a plain DesignJet 500.
Any help is appreciated.
